97 psd problem?
Old Nov 25, 2003 | 06:34 PM
samthemountainman's Avatar
samthemountainman
Question 97 psd problem?
my '97 psd wont start when cold out without plugging it in.
it dies every once in a while just putting it in gear and it's been surging while driving down the road, it does this every once in a while.
i've replaced the glow plug relay and cps on it last winter. if anyone could give me any ideas. thanks
Old Nov 25, 2003 | 06:46 PM
Quadzilla's Avatar
Quadzilla
When the truck nearly dies, is it only when the engine is cold, or does it do it when warmed up?
The fact that you're truck won't start unless it's been warmed up, and since you've already replaced the glow plug relay, I'm thinking you either have some bad glow plugs, or faulty wiring in the valve cover gaskets.
Old Nov 25, 2003 | 06:57 PM
samthemountainman
usually when its warmed up after a couple of minutes, when you put it in gear and sometimes while driving.
Old Nov 26, 2003 | 05:42 PM
samthemountainman
I'm still wondering why its running poorly, because it cant be the cam sensor, unless it was a bad one.
