Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
How do you store your funnels
Old Nov 25, 2003 | 06:20 PM
broncoman604's Avatar
broncoman604
Just wondering how everyone stores their funnels after using them to keep from having a mess?
Old Nov 25, 2003 | 06:40 PM
Bargod's Avatar
Bargod
All my funnels have a little hole on them, either put there by the manufacturer or by me. I hang them on a wall in my garage witah a drip tray under them, that way they can drain and not get all over everything.
Old Nov 25, 2003 | 07:16 PM
Torque1st's Avatar
Torque1st
Posting Legend
There are more topics on care and storage of funnels here that can be found with the search function for more ideas.
https://www.ford-trucks.com/forums/s...el%252Bfunnels
Old Nov 25, 2003 | 08:10 PM
sagebel's Avatar
sagebel
I use a piece of rain gutter and screw a piece of plywood over the open side(using gutter screws). The plywood has hole drilled for my funnels and the gutter runs into a oil bucket.
Old Nov 25, 2003 | 10:02 PM
f350xlt460's Avatar
f350xlt460
coffee can hung on shelf and stack funnels in the can. easy as can be
Old Nov 26, 2003 | 12:18 AM
tigerman's Avatar
tigerman
The long neck funnel for transmission fluid is just used occassionally and is bagged in plastic with an absorbent paper towel in the throat...and thrown on an upper shelf, out of the way. A similar funnel for gasoline transfer is bagged and tossed up also. The other smaller ones are stacked inside a 3 lb coffee can with some paper towel in the bottom. Depending on what I'm doing, I'll wipe those out real good before I use them.
Old Nov 26, 2003 | 08:43 AM
u130747's Avatar
u130747
I stack them in a coffee can with paper towel in the bottom. Every so often I replace the can and paper towels with new ones.
Bert
Old Nov 26, 2003 | 09:17 AM
maa139's Avatar
maa139
On the top shelf in a 2 liter soda bottle with the top cut off with a plastic freezer bag covering it to keep out the dust.
Old Nov 27, 2003 | 12:50 AM
kevin71100's Avatar
kevin71100
I must be a clean freak to some extent. I rinse my used funnels out with gas and then dry them off and out, then store them up side down on a dish towel that I stole from work. Also I stuff a paper towel in the neck to keep out grit, and absorb any wet residue.
I also on occasion rinse out my oil catcher pan with gas to keep the build up inside to a minimum and keep oily dirt from building up on the outside of it.
