Diesel Conversion
Engine, radiator and it's mounts, suspension up front as the diesel is heavier, sound proofing, trans, drive line length, transfer case adapter, tear down the trans to install the matching output shaft, fuel system, exhaust system, frame mounts for the engine, dash/tach, all the related wiring that was not installed for a diesel as it was not originally a diesel including the glow plug system and second battery and tray and relay and what not, and check to see if your gearing will give you decent freeway speeds with the lower maximum RPM range of a diesel, if not, change the gearing!
A lot to consider, that and if you dont do a first rate job (like stock) it will hurt the resale value big time, and will still hurt it some even if you do a good job.
It would be easier, a heck of a lot easier and cheaper to fix up and sell or part out what you have and buy a stock diesel truck to start with, rather than swap all the related components and have the truck down and be working on it forever and a day, and with the donor truck, nothing is new so you might be swaping in something that does not have a whole lot of life left to it.
Makes me tired just thinking about all the work involved.
