71/74 302 headers upgrade?
Old Apr 10, 2024 | 10:36 AM
veteran2's Avatar
veteran2
got a 74 f100 with a recently rebuilt 1971 302, less than 500 miles, dual exhaust and electronic ignition. engine is nicely painted, headers are rusty and in need of cleaning/painting. but i'm thinking these headers are from the '74 302 and if i'm taking them off it might be a good idea to upgrade, any recommendations on best choice?
Old Apr 10, 2024 | 05:43 PM
73explorer's Avatar
73explorer
There have been many discussions on this subject here on FTE. For a stock or mild engine, the general consensus is to stick with the stock manifolds. They will work just fine. Unless your engine is "built" you really won't see any improvement from headers. Headers are hot and noisy, difficult to fit on the right side, and can lead to "cooking" the starter motor. Just leave well enough alone. You could have your manifolds sandblasted and then paint the with high-temp header paint.
Old Apr 10, 2024 | 08:36 PM
redroad's Avatar
redroad
If the headers fit and have at least a 3/8" flange I'd rework them if the exhaust bolts are well preped before you try to take them out. If that's something you want to risk, then pull them off and bead blast and ceramic coat them. Add a set of ARP exhaust studs and you're golden.
Old Apr 12, 2024 | 08:26 AM
veteran2's Avatar
veteran2
good info from both of you, thinking with less than 500 miles bolts shouldnt be too difficult to remove
Flamin5.0
May 14, 2021 03:13 PM
Branded
Ford Truck Parts for Sale
Mar 27, 2014 05:11 PM
Cody_302
Feb 6, 2011 09:52 PM
Spydycarnge
Exhaust Systems
Jan 24, 2010 01:19 AM
