Ford 360 motor update
Old Apr 9, 2024 | 06:48 AM
downrange's Avatar
downrange
Hello everyone!
I am looking at taking my FE 360 stock motor and doing a few upgrades. My question is, i am taking the stock two barrel intake and carb off and putting in a four barrel intake with Holley 600cfm carburetor, Do i need to do an upgrade to the fuel pump? Or with the stock fuel pump be ok with this increase of fuel demand?
Other changes include, installation of Hedman long tube headers, replacement of stock starter to high torque mini starter, distributor/wires/plugs, lots of chrome, new seals and paint.
Old Apr 9, 2024 | 07:11 AM
Drivewayfabricator's Avatar
Drivewayfabricator
I think the stock pump will work fine for those minor modifications. If it turns out that you have fuel starvation issues later, it's easy to swap to a higher volume pump.
Old Apr 9, 2024 | 07:51 AM
73explorer's Avatar
73explorer
From a performance standpoint, you're wasting your money on headers. They will add little performance to an otherwise stock engine. They do they best work with a "built" engine at higher RPM. Long tube headers are also hot and noisy. If your stock manifolds are in good shape, stick with them.
You didn't indicate what you're going to do with the distributor, but if you want electronic ignition (a good idea!), I strongly suggest you keep your stock distributor and install a Pertronix Ignitor and Pertronix Flamethrower coil. Low cost, no muss, no fuss, very reliable, very easy to install. I have them in my '73 F100 (360) and '72 Mustang (302) and they've never given me a problem.
Why the new starter? The stock starter will serve you fine. If it craps out some day, you can get another one at your local auto parts store for not much money.
Sorry to rain on your parade. If you have money burning a hole in your pocket, have the 360 rebuilt and install a 390 crank/rods/pistons to bring it up to a 390. That's money well-spent. If my 360 ever dies, I plan to do exactly that.
Old Apr 9, 2024 | 09:01 AM
kenny nunez's Avatar
kenny nunez
2xs on the headers. Also they are very hard to route on the right side crossmember and not worth the hassle.
Be sure to get a dual plane manifold. If your truck is automatic get a wide ratio planetary gear set while having the transmission rebuilt. That along with a 3.50 axle ratio will also wake up a 360. If your truck is a standard try to find a wide ratio 4 speed top loader from a Mustang or convert to a 5 speed with overdrive. If you have dual exhaust be sure to have a balance or “X” pipe which will smooth out the exhaust pulses.
Old Apr 10, 2024 | 04:49 AM
downrange's Avatar
downrange
Thanks for all the help. I'll definitely look into the pertronix coil and ignition
Pkschmitty
Nov 30, 2020 12:23 PM
grockin2004
23
Jan 22, 2010 04:41 PM
Hellbore
May 25, 2006 03:20 PM
charles jones
Oct 19, 2005 08:11 AM
TheImpaler
Mar 10, 2004 06:53 PM
