Electrical/ignition Switch ?
Old Apr 7, 2024 | 07:06 PM
BBF4's Avatar
BBF4
As I am fixing up the wires I got to thinking. How much can the ignition switch safely power (still a 6 volt system). I was thinking engine, electric wipers, heater blower, and an original 6 volt tube radio. Is that too much to run through the switch?
Also what it the bulb number for the instrument lights and the high beam indicator?
Old Apr 7, 2024 | 07:16 PM
52Flthed's Avatar
52Flthed
As to your question, I would follow the original schematic. One note i will share is I believe the ignition switch is run through the two circuit breakers 30 and 15 amp behind the dash - make sure that the bus bar, it's a brass flat bar that connects the two circuit breakers is taken off and cleaned both sides. My whole truck was rewired in 2021 and this was missed. Looked good one side, but the other side was totally corroded green. Once this was cleaned it solved a lot of problems in the charging system as well as ignition.
Old Apr 7, 2024 | 07:20 PM
BBF4's Avatar
BBF4
I will be sure and check that.
Thank you!
Old Apr 7, 2024 | 08:28 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Ditto on following the stock 6V wiring plans as that supports everything you mention just fine.
As for bulbs, here is a generic 48/56 bulb chart:
A back of the napkin chart:
Sealed Beam Headlight: #6006
Double contact parking lamp and tail light: #1154
Single contact: #1129
Dash indicators: #51
Sonic001
Oct 13, 2023 08:28 AM
Sonic001
Oct 10, 2023 01:57 PM
MensaGirl
2004 - 2008 F150
May 13, 2018 05:36 AM
OK F1
Mar 27, 2018 04:28 AM
robert paul
May 26, 2008 01:41 PM
