Help 89 5.0 Elect. Wont start
Old Apr 6, 2024 | 05:43 PM
Carnage018007's Avatar
Carnage018007
2nd Gear
Angry Help 89 5.0 Elect. Wont start
Relay chatter w key on wont start draws down instantly
Old Apr 6, 2024 | 06:16 PM
spurredon's Avatar
spurredon
From what you are saying it kind of sounds like the relay. It shouldn't chatter but pull in and stay there as long as the key is turned to the start position!
Old Apr 6, 2024 | 09:20 PM
Soup bean's Avatar
Soup bean
Check the battery voltage with a volt meter. It should be just over 12 volts. Clean and reasonably tighten the connections at the positive and negative battery terminals. Disconnect the negative cable first and reconnect the negative cable last, if you remove the battery connections to clean them.
Where you can see the strands of wire, near their terminal ends, are they corroded? If so, they may need replacement.
Clean and tighten the connections at the fender mounted starter relay (aka solenoid). Don't over tighten those nuts, that relay will break.
Check the cable that runs from your battery negative terminal, to the front of the engine block, and/or frame.
Is it corroded?
Old Apr 7, 2024 | 12:39 PM
FuzzFace2's Avatar
FuzzFace2
Is it corroded?
it should not be " block and/or frame" but block AND frame.
You need to ground the block AND frame AND cab so a 10 ga wire from motor to fire wall.
If you did just the motor and not the frame and cab how are they grounded?
Cab sits on rubber mounts and fuel tank senders are grounded to the frame.
This is what the factory did, all 3 places.
You can never have to many grounds.
Dave ----
Old Apr 7, 2024 | 03:33 PM
Soup bean's Avatar
Soup bean
Dave ----
​​​​​​I use "and/or" because my truck no longer has a connection point from the negative battery cable to the frame. I discovered this when I replaced the engine block ground cable.
I suspect the engine was pulled by a previous owner. There is the connection point at the frame, but rather than try to clean it and solder cable to it, I added a jumper from the firewall to the upper intake.
Do the electrons know this is wrong? Apparently not.
Would I have removed that factory frame connection myself? No.
But as long as everything is bonded together with clean connections, it works.
On the subject of those factory braided jumpers, they're probably a good thing to take a look at and maybe replace after 30 plus years. I'll probably add them to my list of things to do.
David1958
Oct 10, 2011 10:43 PM
Capedunes
1978 - 1996 Big Bronco
Oct 27, 2004 05:35 PM
REMILLER
May 18, 2003 09:16 PM
