Weight distribution hitch
Old Apr 6, 2024 | 10:26 AM
1401king's Avatar
1401king
4wd Low
Hey gang. My first post. I can’t seem to find what I’m looking for in the search.
I just bought 2008 f350 cab/chassis with an enclosed service body. Weighs about 7520.
I’m looking at an equipment trailer or car hauler. I’m getting paranoid on how much I can tow.
In 30+ years in construction I’ve never paid much attention to towing numbers but haven’t pulled anything crazy either.
Anyway, to my point. Looking at towing numbers, it mentions weight distribution numbers which are considerably higher.
I’ve never seen a weight distribution setup on a regular trailer. Do I need a weight distribution hitch to achieve, what seem to be, regular towing weights?
I hope I’m making sense.
I would greatly appreciate any information.
Thanks in advance.
Old Apr 11, 2024 | 11:51 AM
FuzzFace2's Avatar
FuzzFace2
My take on WD hitch is to level out the puller & trailer.
Most of the time when you hook the trailer up the rear will drop down taking weight off the steer wheels.
Being you have a 350 you may not have the rear drop down if it dose I cant see it being much.
I say this as I used a 76 E350, 460 / C6, to pull a long boat trailer converted to haul 2 cars.
Most of the time it was 2 Jeeps we took to off road races in the north east,
It was heavy with the wood decking but did not drop the rear of the van or take weight off the steer wheels.
We backed the first car on to put the motor weight closer to the trailer wheels and drove the 2nd on for the same reason.
I would say give some short pulls to see how it handles and adjust from there.
Dave ----
Old Apr 11, 2024 | 11:55 AM
1401king's Avatar
1401king
4wd Low
Dave ----
Thanks for the information. I didn’t realize that was the job of a WDH. I appreciate it
Old Apr 12, 2024 | 06:53 PM
FuzzFace2's Avatar
FuzzFace2
It is in the name Weight Distribution
It can also help control sway by its self but some hitches have hook up for add on sway control.
I think the extra sway control is needed more travel trailers where they have large flat sides that wind hits and pushes the trailer that causes the sway.
Flat bed equipment trailers is not such a problem at least I have not had any with them (when loaded right), mine were / are car trailers but have pulled a travel trailer or 2 also.
Dave ----
Old Apr 17, 2024 | 02:59 PM
justanotherjo's Avatar
justanotherjo
Dave ----
You are almost correct. The rear sagging under load is not what lifts the front end, though, it's the weight on the ball vs the weight in front of the rear axle. The rear axle acts as a fulcrum, regardless of sag. If you compare an f150 to an f250 or f350 with the same wheelbase, the front end will lighten by the same amount with the same trailer load, but the F250 & f350 can haul more without a WDH because they are much heavier vehicles. The frame is much heavier to handle the higher payload capacity, this heavier weight causes the lift on the front end to be less noticeable when driving. lightening the front end by 100lb makes less difference in stability on a 7000lb truck than it does on a 5000lb one. Also, a longer wheelbase truck will not be as affected as a short wheel base one due to 2 factors: weight and length of the lever (the part of the truck in front of the rear axle). It's simple leverage, the longer the lever, the more pressure it exerts downward.
sailorman3
All Things Towing
Sep 10, 2021 07:35 PM
Hesson81
All Things Towing
Feb 28, 2019 10:19 AM
BPCheeta
All Things Towing
Jun 9, 2017 12:59 PM
Rusty_S
May 18, 2014 06:41 AM
silvercc
Mar 7, 2006 09:28 PM
