British Columbia British Columbia
Join Chapter, Leader: F350towing
Clutch replacement
Old Apr 5, 2024 | 12:17 PM
rocketroy's Avatar
rocketroy
Clutch replacement
Hi guys.
i was hoping someone might know a tech that could do a good job or replacing my clutch and slave on my 1990 f150 302 4x4 lariat .
i did the one on my 88 ranger before mostly the same only smaller.
i was much younger and had more free time then.
Everything in this truck is big and heavy.
this is just a weekend warrior..if it’s done 100% correctly and we’ll..it should outlive me , then it will be my kids problem
thankyo
roy in Vancouver
Old May 16, 2024 | 03:20 PM
rocketroy's Avatar
rocketroy
All done .
I just want to let you guys know that I had the clutch done at Mr transmission in North Vancouver British Columbia they did an amazing deal and while they were there they replaced the rear main seal so and it drives beautifully so I'm happy with that just to give you a Roundup of what actually happened
I did order a new clutch master cylinder from RockAuto but they couldn't use it it was a metal one and they said I think they said it had no place for a neutral light or something was missing there was no place to put a neutral light or something was wrong so they had to order one locally so now that is at my house and too late for return
Old May 16, 2024 | 08:00 PM
JJF20's Avatar
JJF20
Good to hear. Good to know which locations do good work with a franchise/chain stores. I’ve had mixed results with them, different locations.
HeavyRightFooT
Jun 13, 2020 01:57 PM
Reg Wal
1983 - 2012 Ranger & B-Series
Jan 1, 2008 07:42 AM
OffRoadArcher
Feb 7, 2004 01:45 PM
