Tremor
Old Apr 3, 2024 | 08:46 AM
Member No. 1's Avatar
Member No. 1
Rather Be Rid'n!
Tremor
Quick question, other than cosmetics, what is the differences or makes a SD a Tremor. I'm more interested with the suspension side. I know the front diff is a limited slip.
Old Apr 3, 2024 | 08:53 AM
BadDogPSD's Avatar
BadDogPSD
Small factory lift, trail mode, cool Tremor stickers on the bed.
Old Apr 3, 2024 | 08:59 AM
honda250xtitan's Avatar
honda250xtitan
the front sway bar is thinner and more flexible.
Old Apr 3, 2024 | 09:37 AM
Poncho450's Avatar
Poncho450
Don’t forget the cool Tremor sticker on the shocks! 😁
Old Apr 3, 2024 | 10:14 AM
4wd6.7L's Avatar
4wd6.7L
The suspension difference is fairly minor. Tremor uses a taller coil spring that gives about 1-1.5" of lift, and a taller block in the rear. As mentioned above, a thinner sway bar and "Tremor" labeled shocks complete the suspension pkg.
Old Apr 3, 2024 | 10:27 AM
Member No. 1
Rather Be Rid'n!
Thanks for the info guys.
Old Apr 3, 2024 | 01:07 PM
Poncho450's Avatar
Poncho450
Also skid plates and a different type running board.
Old Apr 3, 2024 | 01:27 PM
DPelletier's Avatar
DPelletier
....and two manual/auto hubs.
Dave
Old Apr 3, 2024 | 02:48 PM
1olddogtwo's Avatar
1olddogtwo
F-350 Rear suspension on F250
​​​​​​Believe 6.7 Ho is standard for Diesel model
Old Apr 3, 2024 | 06:51 PM
GAZZILLA's Avatar
GAZZILLA
There’s better aftermarket limited slip or locking front differentials, shocks, tires and lifts than come on the Tremor. I prefer getting a non-Tremor and add my own aftermarket parts.
Old Apr 3, 2024 | 07:38 PM
leadmic's Avatar
leadmic
Shocks are different, the front sway bar is different, and springs front and rear are different. It has a limited-slip front difff along with the electronic locking rear diff. It has rock crawl mode and extended diff and transfer-case breathers. It has different steps/tree kickers or rock sliders or whatever you want to call them. It also comes with lower gears. It also comes with skid plates. All this is part of the Tremor package. Oh and I almost forgot the Tremor bed sticker.
Old Apr 3, 2024 | 07:56 PM
4wd6.7L's Avatar
4wd6.7L
Front yes, rear would depend on what you are comparing to. The rears arr not unique to the Tremor.
Old Apr 4, 2024 | 12:15 AM
honda250xtitan
the sway bar is all that matters IMHO.
Old Apr 4, 2024 | 04:17 AM
Member No. 1
Rather Be Rid'n!
Thanks guys, all the info was helpful.
Reason I was asking, I was thinking of updating my current order to a Tremor as long as it didn't effect the build date.
But for what I'd be gaining vs what I'm looking for, I just don't think its worth the change.
Thanks again.
Old Apr 4, 2024 | 06:34 AM
Poncho450's Avatar
Poncho450
Thanks again.
I have a Tremor. Would I go out and order one for my uses? No. But it was a leftover ‘23 sitting on the lot so I made the deal for it. I like the exterior appearance better than the F 350 XLT Premium that I traded. Would I spend money to turn a non Tremor into a Tremor? Also no. For me that money is better spent paring down loan principal.
The previous truck was more than capable, as I don’t off road. But the tech upgrades on the new truck are impressive to me. More features than any previous XLT that I’ve owned. And that’s been several.
Consider your purposes for a truck and spend as you see fit from there. Beware of advice from the forum. Some folks love to spend the other guy’s money. 😁💰
