I ordered a new F350 6.7 and I did not order the locking rear end. I never take it off road, it comes standard with 4x4. Why do almost all the trucks you see on the lot have the locking rear end option?
The way I see it is the only time I need the 4x4 is when there is chain control. In the last 10 years, I have not used my 4 x 4 three times.
Most order it for the added traction afforded, dealers order it for stock because people want it, and it doesn't cost much.
My truck is 2Wd and I have the e-locker, and have used it a couple of times.
Originally Posted by Member No. 1
I'm not an "Off Road" driver per say, but living in the north east, we get snow, and I like the idea of having a limited slip rear if I ever need it.
But, the e-locker in question is not a limited slip, it is a locker, fully locks the axle, can't be used except in very slippery conditions, otherwise it will bind up.
itll chew the tires up for sure. its fun though. you can also bypass the safety so itll stay locked above 25mph. great for winding dirt roads and getting a little sideways.
If I were you I would likely opt for locking diff, and 2WD. Truck is considerably cheaper and lighter. With 4WD, open diffs, when all the traction os on one front and one rear you then have a “no wheel drive”! With a locking diff, 2WD or 4WD you can always have at least two wheels pulling or pushing.
I got it, but mainly to use if I start getting stuck (or pre-emptive from getting stuck), towing in a grassy/muddy field on my 4 wheelin trips.
Some of the events, they have this kind of temporary parking lot in a field.
I don't offroad the 250, and don't use it in winter/salt. Only other thing I can think of is wanting to get out of the hole quick, in the rain, but basic 4WD
for the first 100 feet is all you need for that really.
Only thing there is that Ford only offers 2WD now on XL's, every other higher trim is 4WD only.
Another reason my next truck, if there is one, will not be a Ford.
A matter of semantics I guess. When I said limited slip I was referring to the Electronic Locking Axle. Sorry for the confusion.
In Canada the Build and Price site only has electronic locking diffs so we get them no matter what (unless you get a DRW). Anyhow, they don't cost much, most people want them so for resale value alone I'd get it. I have a small fleet of trucks and always order limited slip or locker for the rear of our 4x4's. I guess the only downsides would be the cost of the option and a slight increase in complexity.
I have a Toyota Tacoma, that I've bought new in 2003 (That I will be selling as soon as I take possession of my new F 250) and it's a very capable off road machine, and I've needed the locking rear end a hand full of times in the past 21 years. It's better to have it and not need it, than to need it and not have it.....OP, it sounds like you're not likely to need it for your application, but we never know just what the future holds.....
I had it on my 209 F-350 SRW. I used it several times only at my remote lot where the RV was on soft dirt. Another few times I used it to was to tow my 5th wheel through a pasture of wet grass.
Ya it just depends on where you live and what you do with your truck. I agree that most people will probably never need it. I live in the area that was in the national news a few weeks ago for getting over 5 feet of snow (which isn't that unusual for us), and where I live, it's good to have as many tires lock in as possible. The county plows leave packed windrows that can be over 2 feet high, and the front tires will get stuck in those unless you have the rear locked. I don't know why Ford options most trucks with it, but for my needs, having a rear locker is critical.
