Sponsored by: Auxito
keyless entry problem
Old Nov 25, 2003 | 03:25 PM
gdogf150's Avatar
gdogf150
Trying to install an aftermarket keyless entry on my '99 f150 4x4. I was able to find both wires for opening and closing electric locks and power to the locks. My problem occured when I was trying to tie into the power for the locks I shorted the wire. I checked the fuse in cab and engine compartment they both looked fine. I replaced them anyway but power locks still did not work. There must be another fuse somewhere. For a temporary fix I ran a hot wire from a different location to the wire to get power door lock to work. Any ideas where this fuse might be? Thanks for any help.
Old Nov 26, 2003 | 08:21 AM
Racerguy's Avatar
Racerguy
The only fuse the manual shows for your door locks is in the underhood battery box.
Old Nov 26, 2003 | 06:25 PM
1968stepside's Avatar
1968stepside
So the switches are working now that you spliced power back into the system? Just wondering if the door switches are fried. I had my door panels off recently on my '99 and if I did not have both switches plugged in, the circuit was not completed so no power locks.
