I have a 2005 E150 Van, I want to convert the Van using a wrecked E250 or E350. It appears it should be a bolt on, and I would be using 2005 or newer donor. I'm sure others have done this, just looking to see what all is need to complete the conversion.
Thanks!!
The suspension which a big part of what makes a van an E250/350 will not bolt easily to an E150 frame.
From ‘07 or so the E150 sits higher and has 8-lug wheels. Those might have more parts swap potential with E250/350s. I suspect, only suspect, later E150s use the E250/350 frame.
