Strange Oxygen sensor behavior
Old Apr 2, 2024 | 05:52 AM
WHanson's Avatar
WHanson
2010 F150 5.3L Trtan @175K
Posted OBD code that O2 sensor was stuck low. Confirmed that it read close to 0 volts, but actually the sensor is going 0V rail to 1.2V rail periodically with occasionally operating normally in the middle around 0.3v to 0.8V as expected.
Downstream O2 sensor seems to be working normal.
Will look for shorting of wires, but not expecting that is the source of this kind of behavior. Would have expected a solid failure one way or the other.
Has anyone observed oxygen sensing fluctuations back and forth between extremes?
Old Apr 2, 2024 | 12:06 PM
RLXXI's Avatar
RLXXI
What I call a lazy sensor. They'll switch then stop then start repeatedly.
Old Apr 2, 2024 | 12:26 PM
aquanaut20's Avatar
aquanaut20
Confirm the signal and ground at the connector, if that checks, replace the O2
Old Apr 3, 2024 | 07:20 PM
WHanson's Avatar
WHanson
Thanks for the responses.
Changed the sensor… working well!
Old Apr 3, 2024 | 09:00 PM
aquanaut20's Avatar
aquanaut20
Sound like you hit the jack box, now buy a Lottery ticket
svtcobra041
1997 - 2003 F150
Jul 15, 2010 09:19 AM
foxykool
Exhaust Systems
Jan 4, 2010 11:24 AM
69deville
3.8 & 4.2L V6
Jan 16, 2007 05:40 PM
beefster
May 24, 2006 05:06 AM
lds
1997 - 2003 F150
Nov 4, 2003 06:30 PM
