1986 inline 6 engine replacement
Old Mar 31, 2024 | 11:06 PM
ToledoBandito's Avatar
ToledoBandito
8th Gear
Red face 1986 inline 6 engine replacement
Hi all,
im new here. Have an 86 f150 with a cracked piston in cylinder 3. (Carbureted). Mechanic says it can’t be rebuilt. I’m having trouble finding a replacement engine from the re- manufacturers. Been searching for about 2 months now. ATK said they had one but it turns out it was not the correct type of 300. Any ideas where I can locate something compatible? Thanks
Old Apr 1, 2024 | 07:49 AM
Bronco638's Avatar
Bronco638
Originally Posted by ToledoBandito
Hi all,
Welcome to FTE!
If Cylinder #3's only issue is a cracked piston, I see no reason why that engine cannot be rebuilt. Now, if the cylinder wall is scored so deeply that is can't be bored, then maybe I can see it becoming a parts source. There are lots of these engines that are available to be rebuilt. Heck, I bought a running one for $500. I think you might want to get a second opinion on that engine or go shopping for a good running one out of a similar year truck.
Old Apr 2, 2024 | 07:49 AM
FuzzFace2's Avatar
FuzzFace2
Yes welcome to FTE
So why would not the ATK 300 motor work?
The only reason I can see is if it was a 87-92 EFI motor as they done have a fuel pump opening for the pump.
Everything else will work and you could run a electric fuel pump with out too much issues.
Also as said a junk yard motor that could be rebuilt.
Again it would most likely be a EFI motor but being it is going to get rebuilt have the shop open the hole for the pump, told bolt holes are already there.
On your motor with bad piston if the wall is banged up you could sleeve it.
Thing is it could run more than just rebuild a junk year motor.
Dave ----
Old Apr 12, 2024 | 07:28 PM
ToledoBandito
8th Gear
Red face 86 crate engine
Yes welcome to FTE
Dave ----
Thanks Dave! My understanding is that the 85 n&86's had a different head compared to all the other 300's. There are 2 different part numbers for each engine on ATK's (and NAPA's) site. Of course the one that supposedly fits the 86 that I have are unavailable. Didn't know if the other one was useable. Is it head & ehhaust differences, or Block difference too?
Old Apr 12, 2024 | 09:33 PM
BOBWhite12's Avatar
BOBWhite12
Blocks stayed the same besides the before mentioned EFI block had no provision for a fuel pump. Any year head should work on any year block but they did make some changes in the compression ratio and combustion chamber shape with the head. Best of luck
Old Apr 13, 2024 | 08:02 PM
FuzzFace2's Avatar
FuzzFace2
X2 what he said.
Because of the head chamber shapes it may lead to pinging at a lower timing setting.
Now if you were replacing the motor in a EFI truck the EFI heads have thing 2 more manifold bolts as the EFI is so large and heavy it needs them.
But using the EFI head with the old log manifolds you just dont use them 2 bolts.
Dave ----
Old Apr 13, 2024 | 11:01 PM
pmuller's Avatar
pmuller
The only difference in the 85 and 86 heads are that they used shorter valves (4.750") with pedestal mount rocker arms and the 1965 to 1984 used stud mount rocker arms with the 4.810" long valves.
The 85 and 86 heads have the same 76cc open combustion chambers as the earlier heads meaning you can use any of the 65 to 84 engines as a direct replacement engine.
The 1987 and later engines are EFI and the heads have a high swirl combustion chamber that requires a totaly different ignition timing curve than the earlier engines.
mortalis09
WTB - Parts & other
Jul 29, 2010 09:56 PM
bill777
Dec 2, 2007 06:11 PM
buckle97
1983 - 2012 Ranger & B-Series
Jan 30, 2007 07:52 AM
