Steering Column Ground?
Old Mar 31, 2024 | 02:41 PM
Bronco638's Avatar
Bronco638
So yes a jumper across the rag joint is some what common but not on our trucks.
OK, that may explain it then. I've owned a litany of Fords but I've never seen a jumper. However, if they're not common on Fords, then that may explain why I'm not familiar with them.
Old Mar 31, 2024 | 03:12 PM
Franklin2's Avatar
Franklin2
I looked and do not see a brush on the shaft. On a truck without cruise, they have two brushes behind the steering wheel, one of them is voltage in, the other voltage out to the horns, no ground needed. On a truck with cruise, there is a dedicated ground brush. So I suppose the ground brush is right behind the steering wheel. So there no extra grounding rubbing block down in the column. It's a brush up behind the steering wheel.
Carolina Bandit
Apr 20, 2022 05:14 PM
columbia1spring
Nov 27, 2018 04:39 AM
injdinjn
Nov 11, 2011 05:55 PM
sleepyhead416
Jun 26, 2008 06:01 AM
SR71
Feb 28, 2005 09:53 AM
