Trans. Gauge
Old Nov 25, 2003 | 11:30 AM
samkirk1's Avatar
samkirk1
Trans. Gauge
I do not know were to post this question so I put it on this forum. I want to add a trans. gauge to my truck. and then change my trans. valve body. This way I can see if the temp. chanced after the mod. plus I pull a 7000lb. trailer. Can someone tell me if they did it. And how with what parts?
___________________________
1998 F-250 LD
5.4V-8
E40D trans.
Diablo Chip
2 Golden Retrivers
Old Nov 25, 2003 | 02:09 PM
Mike W's Avatar
Mike W
I have done this by welding a fitting to the side of the pan. Just pick the location that will be in the clear.
Old Nov 25, 2003 | 08:45 PM
samkirk1's Avatar
samkirk1
OK that is better than putting something on a trans. line that may leak later. thank you for the help!
Old Nov 26, 2003 | 12:34 AM
BigBully's Avatar
BigBully
Are you wanting to do this to an E40D? If so there is a Port Plug on the Drivers side That a Sender will screw right into Takes about 3 minutes to install.
Old Nov 26, 2003 | 06:34 AM
samkirk1's Avatar
samkirk1
I found it thank you!!! I think the trand pan is made with an alum. and steel, this is not something that I want to weld unless it is my last resort.
