identifying engine on a 1973 f100 please.
Old Mar 23, 2024 | 02:05 AM
Joshf100's Avatar
Joshf100
Hello so I have had this 1973 f100 and I’ve been wondering what engine it has I’ve tried looking and had no luck knowing which engine it has if anyone may please help out if highly appreciate it thank you.
Old Mar 23, 2024 | 04:19 AM
john-9's Avatar
john-9
fe engine family so 360 or 390 or even 428 if you are lucky and someone had changed the engine at one time.
Old Mar 23, 2024 | 04:36 AM
Crop Duster's Avatar
Crop Duster
Most likely a 360 FE, small chance it is a 390. But since all Fe's look alike you can pull a spark plug and measure the stroke, 352/360=3.5", 390=3.78". Use this site to decode the warranty tag. That will tell you what it was born with along with other useful info. Decoding '73-'79 Ford Truck VIN Tags - FORDification.net
It appears in your picture that the vacuum advance isn't connected, if true the thing must not be running real great.
Old Mar 23, 2024 | 12:07 PM
Joshf100's Avatar
Joshf100
Hello Thank you for the reply 🙏🏼, I’ll have to check out the spark plug measurements also the truck runs well maybe I didn’t take a good picture of the engine.
Old Mar 23, 2024 | 02:00 PM
Crop Duster
Your distributor has what is called a dual vacuum canister the fitting farthest away from the distributor is the advance side the fitting closest to the distributor is the retard side. If you only have one vacuum line going to the can it should be installed on the advance side.
Curated Content Editor
Sep 17, 2021 02:43 PM
F100supercrew
Aug 29, 2021 07:39 AM
SeaCarr
Jun 12, 2020 07:47 PM
Xcr600man
Ford Truck Parts for Sale
Feb 7, 2016 05:50 PM
f100project
Tennessee Chapter
Mar 9, 2007 06:47 PM
