2023+ exhaust question
Old Mar 21, 2024 | 04:35 PM
Dwebford's Avatar
Dwebford
7th Gear
It appears that all exhausts are made for the 6.7 and the 7.3. Does anyone know if the 7.3 exhaust will fit the new 6.8? Specifically the Borla cat back.
Old Mar 21, 2024 | 06:20 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I would call Borla and ask THEM.
Heck, you might even luck into a deal where they use your truck for a test mule, get a free exhaust.
Old Mar 21, 2024 | 06:50 PM
Rwhjr's Avatar
Rwhjr
I’m not certain but with it being the same engine block etc I’d say the cat back exhaust are probably a match.
but as someone said, just call the manufacturers you’re interested in and see what they say.
Old Mar 21, 2024 | 07:31 PM
Dwebford's Avatar
Dwebford
7th Gear
I emailed them and they said they didn’t test it, so I couldn’t get much. Figured I’d check to see if anyone on here has done it. Thanks!
Old Mar 21, 2024 | 07:44 PM
Member No. 1's Avatar
Member No. 1
Rather Be Rid'n!
I’ve been looking at several different mfg’s for systems. I saw a few that list their system fit the 6.2, 6.8 &7.3.
Hope that helps.
Old Mar 21, 2024 | 08:01 PM
Dwebford's Avatar
Dwebford
7th Gear
Hope that helps.
Can you share? I’ve seen MBRP, but the drone is unbearable.
Old Mar 21, 2024 | 08:38 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I'd be willing to bet the exhaust is all the same, were it mine, I would go for it.
At worst, you might have to get a muffler shop to make a pipe to get it to connect, but doubt that would be necessary, frames are all the same so it will fit the truck itself.
Old Mar 22, 2024 | 02:56 AM
Timxl23's Avatar
Timxl23
Thumbs down
That’s odd. My dealer Northside Ford in Portland Oregon has a Borla display on the wall and I asked them if Borla built a system for my 2023 f250 Super Duty with the 6.8 LT V8. They said yes, but the system would void Ford’s warranty.
Old Mar 22, 2024 | 03:29 AM
Member No. 1
Rather Be Rid'n!
MPI Exhaust. Guaranteed not to drone. True duel exhaust from the CATs back.
Watch his videos, very informative.
hoot12
Sep 5, 2023 12:23 PM
idi1993f350
Mar 6, 2017 07:12 AM
cumminpwr11
Sep 18, 2015 11:02 AM
ncshooter
Jan 10, 2004 04:55 PM
