Hello, looking for help finding the brackets for my power steering pump on my 390. Also looking for the correct pulley for the pump. I have brackets from a 351m . Would that work? Thanks
2X on the recommendation to consider the Borgeson Saginaw pump conversion kit. I did that on my '76 F-150 FE and it fit perfectly. The Saginaw is so much more capable that it opens up the possibility of a HydroBoost power brake system as well. Of course this is a slippery slope because you'll then want to make sure that your power steering unit is up to snuff, a step that will likely require dealing with one of the two top re-man builders (Red or Blue Top). Linkage and joints to follow.
Then there's cross-over and High steer to consider and the 4' lift to accommodate that ........
