uvch
Old Mar 16, 2024 | 04:48 PM
kitz's Avatar
kitz
uvch
anybody know what kind of problems if any broken insulation and exposed wires under the valve cover would cause
Old Mar 16, 2024 | 05:19 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
Shorts
Bad running engine
Frizzy hair
Shocking the squirrel running around the engine compartment
Fire
Just replace with Ford or International counter OEM and make it right....
Old Mar 16, 2024 | 07:37 PM
97-psd's Avatar
97-psd
The potential symptoms are numerous. Just repair and move on
Old Mar 17, 2024 | 05:49 PM
kitz's Avatar
kitz
i planned on replacing them because a pin was gone. after i took valve cover off to do it i seen the wires like that. i had another set of cover gaskets but they are the same kind bought from ebay. i wont be using them. where do you guys get your motorcraft ones from
Old Mar 17, 2024 | 06:31 PM
Veteran: Navy
Just replace with Ford or International counter OEM and make it right....[/QUOTE]
See previous post... Quoting my own post....
If you must order...
RiffRaff Diesel or CNC Fabrications are about the last two most of us trust.
Never cramazon, fleabay, general internet places, or the corner store..
Replace the harness and gasket at the same time. Save heartache from having to go back in again latter.
Old Mar 17, 2024 | 06:41 PM
97-psd's Avatar
97-psd
I agree with above. The last time I did one I was in a tight spot and bought a standard motor products gasket. Everything looked good it has worked well for the last few years. I have never used the dorman or others brands before but based on my observations, the standard motor products unit was a much better quality. I am not suggesting it over the OE gasket, but it worked in a tight spot.
Klutch5000
Sep 12, 2023 09:17 AM
jleal_21
Oct 8, 2008 05:30 PM
73f350sc
Sep 21, 2004 11:54 AM
