Ok trying to find a tail light bulb for the rear backup light. It is a flat connector style single filament bulb. All I can find are 3057 dual filament bulbs. Will these work for running lights even if you don't need the second filament?
Also, replacement headlights don't have turn signals anymore, the light that was there is clear so where is the running light/turn signal? They call them fog lights. A fog light is not a running light nor a turn signal. WTF is up here.
Also how do you remove the headlight assembly to change out a turn signal?
