7.3 IDI HELP!
Old Mar 14, 2024 | 09:43 AM
Thatold1979's Avatar
Thatold1979
5th Gear
7.3 IDI HELP!
hey guys im new here and im taking a 1991 f250 with a 7.3 idi and a e40d and putting a 1979 f100 body on the chassis. anyways i want to know what wires i can delete the truck was and lariat xlt wit power locks power windows and such and i dont require any of that anymore. If anyone has a wiring diagram i would be extremely great full. Thanks.
Old Mar 14, 2024 | 09:53 AM
Olds64's Avatar
Olds64
Here's a good website with Bullnose wiring diagrams and troubleshooting info.
https://www.garysgaragemahal.com/wiring-diagrams.html
Even with the FIPL and E4OD you shouldn't need much to get that 7.3l to start. Good luck.
Old Mar 14, 2024 | 10:35 AM
Prototypemech's Avatar
Prototypemech
Transmission Computer and the harness which connects to the Vehicle speed sensor, transmission shift position sensor, throttle position sensor, baro sensor.
An Ignition switch for the fuel shut off solenoid, starter, and glow plug controller.
Old Mar 14, 2024 | 11:04 AM
Thatold1979
5th Gear
thanks olds i know the idi only really requires one maybe two wires to run but i dont know too much about the e40d i think on the passenger inner fender is the trans control module but im not too sure ill look at that and see what all can go and what will stay as for other stuff would it be easyer to keep the 79 cluster of retro fit the 91 cluster into the 79 dash?
Old Mar 14, 2024 | 03:28 PM
Prototypemech
Remove the computer behind the driver side wheel well and remove the wiring harness with it. Try to get as much as the harness out without cutting wires. You should only need to clip a few wires associated with power/ground/keep alive memory,overdrive light/switch, and speedo.
You'll need to wire in the 91's psom (programmable speedo/odo module) that's on the back of the instrument console. It converts the vss signal into something the trans computer can use.
Old Mar 15, 2024 | 08:52 AM
Thatold1979
5th Gear
thanks man i appreciate the help especialy since i know nothing about autos hopefully the trans control module is good it wasint shifting into any gars besides 1st or 2nd and 3rd or 4th
Willar47
Jan 3, 2022 12:01 PM
captain4bars
May 27, 2008 11:46 AM
skoto1
Feb 8, 2008 04:45 PM
motobub
Feb 14, 2004 07:38 AM
