F-350 vin
Old Mar 12, 2024 | 04:53 PM
Redman1202's Avatar
Redman1202
4wd Low
F-350 vin
Hi. Can anyone decide this vin?
F37YCA26558
Old Mar 12, 2024 | 10:22 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
F37- '73-'79 2 wheel drive Chassis and cab (F350)
Y- 73-'76 8 360 2-bbl.
C- Ontario Truck
A26558- consecutive unit number / Numerical Sequence of Assembly.
Using https://www.fordification.net/tech/vin.htm
Old Mar 13, 2024 | 08:54 AM
Redman1202's Avatar
Redman1202
4wd Low
Any idea of the exact year?
Old Mar 13, 2024 | 09:15 AM
tbear853's Avatar
tbear853
A26558 is your truck's sequential number, my reading in the link posted above, looks like yours will be a 1976 number.
Old Mar 13, 2024 | 09:36 AM
77&79F250's Avatar
77&79F250
Did you get the vin off the dvrs side door back edge aluminum Warranty tag? Then look at the dvrs side B pillar (below the striker) and look at the Safety Certification sticker (white sticker) and that also has the month and year made.
Yes 79 Bronco tag just for reference.
Feb 79 for this Bronco
Old Mar 13, 2024 | 09:46 PM
Redman1202's Avatar
Redman1202
4wd Low
F-350 vin
Found this today.
Found this today.
Old Mar 13, 2024 | 09:48 PM
Redman1202's Avatar
Redman1202
4wd Low
F-350 vin
36J under axle.
Old Mar 13, 2024 | 09:54 PM
77&79F250's Avatar
77&79F250
Rear axle code 36 is '73-'75 (ratio) 3.73, (capacity) 7.4M, (make) Dana, (model) Spicer 70
Old Mar 13, 2024 | 10:13 PM
Redman1202's Avatar
Redman1202
4wd Low
Thanks Guys
Old Mar 13, 2024 | 10:16 PM
77&79F250's Avatar
77&79F250
Does it not have the White sticker on the B pillar?
Old Mar 13, 2024 | 10:19 PM
Redman1202's Avatar
Redman1202
4wd Low
Just a small round sticker. No real info on it.
Old Mar 13, 2024 | 10:32 PM
77&79F250's Avatar
77&79F250
Interesting that you did not have the B pillar square sticker, like in my pic.
Old Mar 13, 2024 | 11:06 PM
Redman1202's Avatar
Redman1202
4wd Low
Maybe because it was made in Canada?
I will check my F750 (same year) this weekend to see if it has one. Maybe it fell off?
Old Mar 13, 2024 | 11:17 PM
77&79F250's Avatar
77&79F250
Yes probably a Canadian thing "Eh"? That is one sticker that does NOT fall off. It is almost made to be tamper proof. You try to peel it off and it falls apart.
ford highboy!
Mar 13, 2023 07:55 PM
No More Raptor
Jan 26, 2021 02:56 PM
radio flyer
Nov 17, 2017 08:02 PM
fast70
Feb 23, 2010 08:25 AM
leegbee
Apr 21, 2008 06:01 PM
