Rear axle question
Old Mar 12, 2024 | 11:46 AM
OBSession05's Avatar
OBSession05
Rear axle question
94 F150 146k miles (specs under sig if needed)
Watch the video to see what I am referring too.
Pretty sure it's a normal amount of play but I shook the truck side to side and noticed a noise so I took off the wheel for further inspection. Brake drum slid right off with no fuss...which I have never had happen but I don't know if that's necessarily a bad thing. Is all this normal? I am not sure if the play is something to be concerned about or not. I'm probably overthinking it but figured I'd double check. Thank you for your time.
Old Mar 12, 2024 | 12:17 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Normal movement. The rear brakes are out of adjustment.
Old Mar 12, 2024 | 01:42 PM
KorbenCenturion's Avatar
KorbenCenturion
5th Gear
Yeah that's pretty normal, the C-clips that hold the axle in have some play. Just a word of caution though, too much and it'll fall apart. The C-clips will fall out and then nothing retains the axle.
While not urgent I'd start thinking about taking off the diff cover to at least do an inspection and replace the oil. While there consider replacing the cross-pin, C-clips, and if it has a posi the clutches. Those are the parts that wear and cause that play.
Old Mar 12, 2024 | 01:45 PM
Hit Man X's Avatar
Hit Man X
Add at least the outer wheel seals if you pull the cross pin, super easy.
Old Mar 12, 2024 | 01:53 PM
OBSession05
I appreciate the responses. I plan on servicing the diff sometime this springs so I will add that to the list. How hard is it to replace those clips? and how much are they to replace? The rear end needs some TLC so when I finally get the time to do rear brakes I think I might as well go a little further and replace seals as well.
Old Mar 12, 2024 | 02:06 PM
KorbenCenturion
5th Gear
Been a long time since I've looked for those parts, so IDK what it takes to get them these days. Not hard at all to replace though, hardest part is the cross pin bolt. There's a bolt that retains the cross pin and has a small wrench head. Round that head off and you're in trouble, so make sure you have a good 6 point wrench/socket for it. But once that bolt is out the rest comes apart really easy, slide out the cross pin, push in the axles, the C-clips fall right out, then pull the axles out. From there seals pry right out. Tap in new seals and reassemble with any new parts.
Old Mar 13, 2024 | 06:30 AM
manicmechanic007's Avatar
manicmechanic007
That noise can be lessened by an O ring in the C clip groove
Most had the O ring from the factory
Trucks not so much
With the O ring in there, the clearance is still there, it just knocks or clanks less
SirArgus
1983 - 2012 Ranger & B-Series
Feb 21, 2012 08:01 PM
Dads79
Jun 26, 2009 06:35 AM
cadriver
Mar 29, 2007 12:49 AM
bnk66vw
1997 - 2003 F150
Aug 23, 2006 08:49 PM
