todays goings ons
Salt or whatever they spray on the roads stays after it warms up . Then you drive thru the mush and it goes all over and into everywhere........
Not everyone has a garage.............or a SHOW truck...............ha...............lol.......... .....I got a garage , one side filled with a vintage non-SHOW Mercedes Benz...............but that is a WHOLE different story.............oh my............ha
As for snow, up till 2015 I lived in New England and we got snow and all the bad stuff they put on the roads.
My 02 Durango after snow storms I would hit the car wash where they sprayed the under side.
Think that is why the truck is in as good of shape it is because of the washes.
Down here when they get snow / ice they shut the state down as they dont have the equipment to fight it.
They may spray some of the roads before a storm and that is only on the main roads like I40 / I95 / RT1.
I live on a some what main road, NC210, I have yet to see them do any thing on it for storms.
With in a day or 2 anything that was on the ground is all gone.
Heck I dont even own a snow shovel and the plow for the tractor, I have only used to back blade dirt when they did digging in the yard.
Dave ----
Richie the wrench 🔧
Was living in Alabama and that's where I bought my trucks but moved to Cleveland Ohio so to me it's a nightmare for any salt to get on them trucks so I took my diesel truck came down to a friend's house for the winter in mid Georgia. I have three 1986 long beds single cab. Speaking of the fuel tank vent I seen something on this forum about that very thing on my diesel the rear tank takes fuel no problem the front tank gargle and spits it up as if it's full kicks the pump off but I seen the vent hose in there so something's going on with it maybe it's collapsed I'll have to take it apart take a better look and get it working cuz that's a pain in the neck the pump kicking off and going slow.
I remember your post. That vent tube was twisted up good. As long as there isn't a hole in the vent tube allowing it to fill with fuel and blocking air out it will work. At least on the front tank. A twisted up one might not be good for the rear tank which in my experience does not fill as easily as the front. The rear has a long horizontal section. I always use the minimum hook on the autofill pump handle on both tanks. I'm wondering if Ritchie's vent pipe has a hole in it? Could happen with somebody aggressively trying to insert a siphon hose.
Richie the wrench 🔧
I dont know about the diesel tanks but on the gas the vent hose fits into a "holder" both up top and at the tank.
Top holder
If the hose pulled out at the tank end that could be an issue.
I only had a fill issue 1 time on 1 tank (rear?) and thought the worst.
Then when I got back in the truck and switched between the tanks found the tank was full
No issues since then.
Dave ----
Top holder
Dave ----
Top holder
Dave ----
Top holder
Dave ----
the tube goes in the top hole. You can see that getting a siphon hose in there is difficult unless it's small diameter.
Up top at the filler door it's like Dave's photo. The vent tube must be on top on both ends.
Richie the wrench 🔧
Yep diesel is the same as gas. At the tank you have a vent tube support:
The following users liked this post:
Tonto Kowalski
32
03-20-2024 12:37 PM
Jbark8
05-21-2023 06:48 PM
