Let's talk tires
Old Aug 21, 2024 | 12:03 PM
  #46
lin 842's Avatar
lin 842
I have to go out for a little bit but when I come back, I'll get back in the manual to see how to do a reset.
Old Aug 21, 2024 | 12:13 PM
  #47
jcb804's Avatar
jcb804
Has to be done with outside software. Forscan or a dealer. Can guarantee the tire place did not recalibrate and probably doesnt even have the software to.
Old Aug 21, 2024 | 12:56 PM
  #48
Joe T's Avatar
Joe T
Those tires are really heavy and not highway oriented.
4mpg is a bit much but not unrealistic.
Old Aug 21, 2024 | 12:59 PM
  #49
WXboy's Avatar
WXboy
Regarding the MPG discussion... I log my mileage with Fuelly so it's actual math and it's accurate. On stock wheels with 275/70R18 stock tires I was getting 18 MPG on my weekly commute which is about 40-50 miles daily and mixed city/highway. With the 35x12.50R18 Falken A/T4W tires I'm at 16 MPG doing the same driving, same speeds, same usage of the truck.
So, for a 295/70R18 which fits right in between the stock size and 35s, I would expect only a 1 MPG loss. If you lost 4 MPG there's something else wrong.
Old Aug 21, 2024 | 03:36 PM
  #50
Matt In Detroit's Avatar
Matt In Detroit
You need to change revs per mile with forscan. Easy fix, your numbers aren't correct for the new tires.
Old Aug 21, 2024 | 05:55 PM
  #51
FishOnOne's Avatar
FishOnOne
I recall reading on another forum that an owner of a Bronco Sport changed his tires to the Falken AT4W and noticed it took more throttle to get the vehicle to move when at a full stop. Wonder if the rolling resistance is greater with these tires?
Old Aug 21, 2024 | 07:10 PM
  #52
Zork's Avatar
Zork
What are these tires made of? Super glue?
A ~30% increase -or 2 extra gallons per 100 miles- doesn't seem possible to me just by changing thread pattern and the overall tire size slightly.
Old Aug 22, 2024 | 05:32 AM
  #53
jcb804's Avatar
jcb804
If you guys noticed he never recalibrated for the taller tire size and is basing his calculation off the odometer which is reading less than his actual travelled miles.
Old Aug 22, 2024 | 05:40 AM
  #54
Joe T's Avatar
Joe T
The miles are off about 3.5% and yes that calculation makes a difference.
So 13.5 x 1.35 ~ 14mpg.
Totally plausible to loose that with heavier aggressive tread tires. I mentioned it earlier in the thread they are heavy.
He also doesn’t have a large sample to confirm. I bet he lands around 14.5mpg eventually. He should consider Yokohama G015 or Michelins in that size if mpg is a bigger concern.
Old Aug 22, 2024 | 08:07 AM
  #55
GreyShadow350's Avatar
GreyShadow350
On my previous truck (2016 Ram 1500 Quad Cab w/ 5/7L Hemi), I put the Falken AT3W's on it in the stock tire size. I lost 1-1.5 mpg, and the truck felt like it was glued to the asphalt. The truck just always felt heavy/sluggish with them. They also were horrible in the rain, felt like I was driving on snot. Thankfully it didn't snow the one winter I had them on the truck - I feared that. (Took them off the truck having only used them for 6,000 miles.) I know many people here (and on the Ram forum that I used to be a part of) rave about the Falken's, but I don't see me ever trying them again. Especially when Cooper has a similar tire that is 10 lbs lighter. And on my Ram, I replaced the Falken's with Cooper Discoverer AT3 4S tires and loved them.
Old Aug 22, 2024 | 08:35 AM
  #56
WXboy's Avatar
WXboy
That's almost certainly a result of going from a P rated tire to a heavier duty tire. Most of the A/T4W sizes are 3 ply sidewalls and heavier construction across the face of the tire. On a light duty vehicle like a Bronco Sport or even a Bronco that's going to be a very noticeable change.
Old Aug 22, 2024 | 09:34 AM
  #57
lin 842's Avatar
lin 842
I wish I had seen this before I went 2 sizes up. I had asked about that, and everybody said they only lost less than a mile a gallon. I could deal with that. When I first noticed it I thought I was putting fuel in it a little more often and that's when I started checking it closer. When I went to the outer banks, I switched over to the fuel screen on the dash and holly crap 12.5 mph was looking me in the eye. Now granted the truck was loaded and I was pulling my trailer with a golf cart on it. But I did the same thing the year earlier and I got around 17.5 mph with the same load. The truck doesn't seem to mind what I put in it as far as load it drives and handles the same loaded or empty. Although it does ride a slight bit better loaded. today when I go out I'm going to try and check my miles traveled by GPS just to see how far the speedometer is off.
I'm posting the tire size comparison thing I found online.
Leef250
Nov 10, 2016 06:07 PM
tcat
Ford Truck Parts for Sale
Jan 22, 2015 02:13 PM
