1960 8' bed weight
Old Mar 5, 2024 | 09:47 PM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
1960 8' bed weight
Does anyone know the bed weight of a 8' bed? I'm just one person and want to pull the bed for repairs.
Old Mar 5, 2024 | 10:55 PM
Archie’s Beater's Avatar
Archie’s Beater
I don’t specifically, but it’s heavy. I tried to tip it up, but it was heavier than I wanted to try. I’ve used equipment when I needed to move it.
Old Mar 6, 2024 | 06:40 AM
bjmayberry2
I'm hoping I can use my engine hoist but I was hoping someone knew the weight before I tried.
Old Mar 6, 2024 | 07:21 AM
Archie’s Beater
depending on the rating for the hoist it should be fine. Just take it slow it’ll be unwieldy, likely much bigger than your hoist. Try and lift from a center point if possible.
Old Mar 7, 2024 | 08:28 PM
JohnNewb's Avatar
JohnNewb
Engine hoist and a helper should work. When I lifted my cab it would have been nice to have someone to help steady it when I rolled it around.
Old Mar 7, 2024 | 09:47 PM
bjmayberry2
I've used my engine hoist to remove my 53-56 cabs several times. But I'm thinking the bed is heavier and even more awkward. That's why I am trying to get a bed weight.
Old Mar 17, 2024 | 09:22 PM
1952henry's Avatar
1952henry
Quick Google showed 4xx lbs. not the same make and year as yours. Removing tailgate would save weight, but also change balance. A strap through each corner stake pocket, and a load leveler would make it manageable, I believe.
Old Mar 17, 2024 | 09:27 PM
bjmayberry2
Thanks, 4 people can lift it so I figured under 500 lbs but I wanted to be sure before I tried using my engine cherry picker.
dstuek
Sep 21, 2022 10:09 AM
borregoman
Feb 11, 2022 06:32 AM
johnfin1
May 4, 2019 02:28 PM
muleshoejoe
Aug 24, 2008 11:28 AM
one_wicked_element
Oct 24, 2007 11:52 AM
