I read all the post about the bouncing speedometer
Old Mar 4, 2024 | 04:02 PM
Nailman1996's Avatar
Nailman1996
4th Gear
I replaced my rear wheel speed sensor because I had check engine code. Now my speedometer bounces like crazy after 55mph. Where can I find the original part? All the local parts stores have the same plastic sensor.
Doing a google search I have found one’s that look like my original. But they are for the transmission not the rear end.
Old Mar 4, 2024 | 04:59 PM
My4Fordtrucks's Avatar
My4Fordtrucks
What vehicle? You threw the sensor in because of the code or because the sensor tested bad?
Old Mar 4, 2024 | 05:03 PM
Nailman1996
4th Gear
Update
1996 F150 2wheel drive, automatic w/over drive, 5.0 motor. The engine code was replace Speed Sensor!
Old Mar 4, 2024 | 05:16 PM
My4Fordtrucks
There is no code that says “replace this part”. Did you test it? What brand did you replace it with? Still available from Ford.
Old Mar 5, 2024 | 04:53 AM
manicmechanic007's Avatar
manicmechanic007
Those wires that go into the connector on the rear axle speed sensor have a habit is breaking inside the insulation
Test the ohms of your sensor and its voltage output when spinning the rear axle
Test the VSS PID and see if it fluctuates the same as the speedo
RecycledTeen
Jan 17, 2010 06:56 AM
MX_Fyrcaptain
13
May 8, 2009 10:52 PM
TPM
Apr 12, 2007 08:21 PM
1995fordf150
Jul 17, 2005 12:04 PM
