23 F350 Proximity unlock issue
I had this problem occur again today. I drove 70 miles, exited the truck and tried to touch the door lock and it did not work. I locked the truck with the key fob and then tried to unlock it with the door handle. Did not work. I tried it multiple times and the door locks did not work. I was away from the truck for about 45 minutes and when I came back to drive home, everything worked fine. There is definitely an issue with the proximity and door handles.
couple of things come to mind 1 that you probably can not check is what the bcm thinks the battery state of charge is,if it gets too low ive seen it cause this issue. 2 on my own ive noticed if i put my cell phone in the same poket with my fob it wont work most of the time.i just move my fob or phone to another pocket and all is well
Approach detection just failed to work for the first time this morning on my 2024 F250 Lariat. Had recurring updates set for every day at 4am. I just changed that to the minimum of 2 days a week. I’ve read enough about Super Dity trucks and a mysterious battery drain. Damn this is disappointing, hope it doesn’t get any worse.
These vehicles need to come with a battery maintainer!
Watch this.....
Did you notice the proper way to charge the battery?
Can’t send DM
I cannot send you a DM. Says I don’t have those privileges. Please advise if there is another way to contact you.
I am having this same problem with my 2024 F450 lariat.
I will drive the truck and then when I get to where I am going and shut the truck off and open the door, none of the lock or unlock buttons on the key fob, inside of door or the door handle work. I also cannot open my tailgate. Everything else works except anything that has to do with locking or unlocking the truck.
I let it sit for 2-3 hours, everything is back to normal. Until the next time I drive it.
I am driving it to the dealer tomorrow and will post an update as soon as they figure it out.
It works without any problems for a couple weeks when I disconnect the batteries
Knock on wood they updated programming on mine. No issues since. I don’t drive it much though. I have I think 2700 miles on it since I bought it at the first of Dec lol. I have to take mine in for other crap though. I think the front door speaker is busted and I hear the left ceiling speaker distorting on calls and with certain music. I am going to make them look at the wavy right side rear bumper as well. I looked at other trucks and they aren’t like that. The passenger seat cover has also came loose at the front under the seat. They also are supposed to fix the misaligned door badge. It’s off by 4 degrees from the factory lol.
Mine failed to open again this morning. I used the key fob to remote start it and that worked just fine. Just could not open the doors using the touch feature. Battery voltage on the dash said 14v. Good times!!! Maybe it will work at lunch time today but who knows.....
I am also getting the open door chime more often as I am driving. Nothing show up on the dash. Just the open door chiming going off.
Did you ever figure this out? I have the same issue, unable to arm (lock doors), disarm (unlock doors) with fob while parking lights are on. I'm able to use fob once parking lights extinguish.
We will see.
