Misfires when hot
Old Mar 2, 2024 | 01:30 PM
OlShtBx's Avatar
OlShtBx
1st Gear
Misfires when hot
1990 F150 300 I6:
I have been getting a hard misfire after the engine gets hot. It’s intermittent, sometimes it will be the moment it gets to operating temp others it after driving for over a hour. It feels like I’m running on 4 cylinders, appears to start absolutely drinking gas, and the whole truck is rattles.
I’ve replaced plugs and wires, fuel filter, and both fuel pumps have been replaced within the last year or so.
Any advice? Thank you in advance.
Old Mar 2, 2024 | 01:44 PM
Prototypemech's Avatar
Prototypemech
Have you checked for engine codes? Historically, this a common ICM failure, but first step is to check for codes.
Old Mar 2, 2024 | 01:49 PM
rla2005's Avatar
rla2005
Agreed very common symptoms of a failing Ignition Control Module (ICM) but a failing PIP sensor can do the same thing. Check for codes first.
Old Mar 2, 2024 | 04:34 PM
AuroraGirl's Avatar
AuroraGirl
Show me a picture of your spark plug wires/plugs/distributor,
And can you show me a picture of your old plugs?? If you dont have that, send a picture of one of your plugs with the wire removed while in the head
Old Mar 3, 2024 | 06:47 AM
tjc transport's Avatar
tjc transport
i ain't rite
also check coil. a bad coil will start breaking down, or fail when hot. but work fine again once cooled off.
Old Mar 3, 2024 | 07:24 AM
Mudsport96's Avatar
Mudsport96
Could be the intake air temp sensor too. Sounds similar to an issue I had about a year ago.
97Beast
19
Sep 9, 2016 01:50 PM
Cascadia
1997 - 2003 F150
Sep 2, 2016 04:26 PM
redmom74110
Feb 25, 2008 09:14 AM
navicapolia
18
Oct 23, 2007 10:27 PM
Doug333
Dec 18, 2001 12:15 AM
