Is this normal?
Feb 25, 2024 | 12:14 AM
Feb 25, 2024 | 04:45 AM
Looks normal for the rubber bushing. The u joint looks like it was lubed and has dirt residue on it, normal.
Feb 25, 2024 | 06:41 AM
The rear sway bolt could probably use a turn or two but looks pretty normal otherwise along with the rest of suspension.
Feb 25, 2024 | 09:49 AM
It doesn’t look a little loose?
Feb 25, 2024 | 09:53 AM
Quote:
Originally Posted by
Sailmike
Did you grab it to see if it had play or really loose?
Feb 25, 2024 | 06:55 PM
Yeah and didn’t seem to have play.
Feb 25, 2024 | 08:19 PM
Sailmike
Doesn't look loose to me. Have the parts in the photos been worked on, is that why you are concerned with them not being properly torqued? I've seen front sway bar end link torque spec at 59 ftlb, the rear is probably the same. You could check it if it bothers you.
Feb 26, 2024 | 12:16 AM
I seem to be hearing rattling when driving on rough pavement, but I’m hearing impaired, so I’m not 100% sure.
Feb 26, 2024 | 05:28 AM
that front ball joint is a bit suspicious to me.
Jack that side up just enough so the wheel will spin.
Then use a pry bar under the wheel and liff it while watching the suspension and all the joints. All should be tight.
Will have to use someone to operate the pry bar so you can watch it all.
Feb 26, 2024 | 04:46 PM
Thank you for all your replies.
M-1 guy
Oct 21, 2023 02:27 PM
grinnergetter
867
Apr 16, 2020 10:31 PM
firstrider
Oct 19, 2019 10:51 AM
AAM
Projects
15
Oct 9, 2010 06:02 PM
86351wProject
Texas Chapter
Aug 24, 2010 01:19 PM
