Sponsored by: Real Truck
2002 f250 breaklights
Old Feb 24, 2024 | 11:14 PM
Or_shane's Avatar
Or_shane
1st Gear
So i havent been able to figure out why my breaklights wont work. Bulbs are good, tail lights and blinkers work, also the cab breaklight works
Old Feb 25, 2024 | 10:53 AM
99f350sd's Avatar
99f350sd
Brake light switch under the dash. or bad wire...main plug drivers side rear of truck might be corroded.
Old Feb 25, 2024 | 02:54 PM
redford's Avatar
redford
FTE Leadership Emeritus
Welcome to FTE.
At this point, you're just going to have to get a voltmeter or a test light. You need to trace the signal from the brake light switch to the lights and see where you're losing the voltage.
wisk
Jul 19, 2018 05:56 PM
FordFunRun
Aug 8, 2017 08:51 AM
.Artisan.
Mar 29, 2016 09:11 AM
sporttaz
Nov 12, 2012 05:57 AM
FordPickup460
May 15, 2006 11:37 AM
