High vacuum
Since I have gotten it up and running it has ran crappy but only when you let off the gas then get back on it (worse when you downshift or come to a stop and take off from an idle). But unknowing the condition of the truck previously and hoping it has just sit for a while I figured it was old gas. Anyway fast forward 500 miles and a can of seafoam, still the same. I have been researching forums and asking friends since I got the truck since this is my first ford.
I have replaced the sparkplugs (which helped my problem slightly), checked the codes with a snapon scanner (I have none), made sure everything looks good (it's got new plug wires, a new egr valve(which I have checked and is working properly), new distributer cap and clean air filter) I have checked for vacuum leaks with a can of brake clean and everything looks good.
After doing all of this, still nothing and it still has the same almost hesitation when getting off then back on the gas, especially under load and always after idling. I also has a slight miss at idle that goes away as the rpms go up that someone can hopefully chime in and let me know what that is, I'm going to pull distributer cap this weekend and see what the rotor looks like and the condition of the cap.
So with the slight miss at idle and the hesitation I was almost certain what I had was a small vacuum leak that just wouldn't show itself so i went to harbor freight and picked up a vacuum gauge. This is where it gets interesting and has me confused, pulled a vacuum on off the manifold tree at semi cold start idle I had 24inhg!!!! So blipped the throttle drops down jumps back up 28 then 24inhg.
So here i am baffled how does a truck with 250,000 miles on it have 26inhg of vacuum at idle? I still don't know?!?! If someone could help me understand this that would be great.
Anyway after thinking about it for a while I realized that the fuel regulator is controlled by vacuum, the higher the vacuum the lower the fuel pressure. So putting 2 and 2 together I took the vacuum line off of my fuel regulator, plugged it and low and behold I have no stumble off idle or when engine breaking and getting back on the throttle. HIGH VACUUM WAS KILLING MY FUEL PRESSURE!!!
my question is how the heck does my engine have 24 inches of vaccum and if i replace my fuel regulator (which i am going to do because i have a valve cover gasket leak and it will be right there anyway) how am I going to get my vaccum down to be able to use my fuel regulator, or can I just run it without it without killing my gas mileage which I need because I drive 90 miles a day to work.
Thank you everyone that took the time to read that I usually try to diag and fix my own stuff but this one has me thrown for a loop. Also if this fixed anyones problem that they have been having let me know I always like to give information on anything I can help with
i think you diagnosed it correctly, did you replace your fuel regulator yet?
I run a dash mounted vacuum gauge, helps not press the pedal. .
what’s your vacuum read while you accelerate?
I am going to borrow a vaccum gauge from the part store and compare results. Also i will borrow a fuel pressure gauge with the correct fitting so i can see what my fuel pressure is with vacuum applied and released from the fuel regulator. Thanks everyone for your help.
now, back to your other thing, can you catch us up on your fuel pressure question/situation? And you can get compression if youd like, at this point its pretty healthy but it never hurts to know what youre at so you know what its normally at so if you have issues in the future you have a frame of reference.
