Vin decoding
Old Feb 21, 2024 | 07:25 PM
TexacoRick1966's Avatar
TexacoRick1966
3rd Gear
Vin decoding
Can someone help to decode a vin
Old Feb 21, 2024 | 08:25 PM
85e150's Avatar
85e150
Welcome to FTE.
I moved you to the forum for your '66.
F10 = F100 4x2
A = 240 1V six in line gas engine
C = Ontario Truck Plant
775004 = 1966 numerical series, November 1965 production
115 = 115 inch wheelbase
M = White
F101 = F100 4x2, 4,200 lbs GVWR
281
2 = Blue Vinyl
81 = Conventional Cab.
C = Ford three speed Light Duty manual transmission. Should be the all synchro "3.03" model
09 = Ford 9 inch rear axle, 3,300 lbs capacity, 3.70 ratio
4200 = 4,200 lbs GVWR
129 4000 = 129 certified net HP @ 4,000 RPM
21 = Atlanta District Sales Office
No special order, bought from dealer inventory.
Old Feb 21, 2024 | 08:31 PM
TexacoRick1966
3rd Gear
The interior is not blue but there is blue thread in the seat coverings could this be the blue? The interior is beige.
Old Feb 21, 2024 | 08:51 PM
85e150's Avatar
85e150
Code 4 shows beige. Is it the OEM interior?
I'm going off a '66 Ford Truck Shop manual on line.
https://www.forelpublishing.com/demo/Demo20066.pdf
Too bad Marti Reports cut off a '67.
Another source:
https://www.fordification.info/tech/vin65-66.htm
Old Feb 27, 2024 | 07:57 PM
TexacoRick1966
3rd Gear
Help please deciphering
Old Feb 28, 2024 | 07:52 PM
85e150's Avatar
85e150
F10 = F100, 4x2
A = 240 1V six cylinder gas engine
L = Michigan Truck Plant
A44039 = 1967 numerical series, November 1966 production
U = Medium Green
F100 = F100 4x2, except state of Pa., 5,000 lbs GVWR
381
3 = Medium Green Vinyl
81 = Conventional cab. (I have limited info on interior etc)
C = Ford three speed manual transmission (All synchro "303") (This makes no sense with a 460. 460 was AT only for this model year)
08 = Ford (9 inch) rear axle, 3,300 lbs capacity, 3.50 ratio
05000 = 5,000 lbs GVWR, which as noted above
28 = Louisville District Sales Office
No special order.
This forum is '61 - '66 but I will leave you here unless you want to move this decode up to the '67-'72 forum. Keep in mind the '67 is an oddball year, with some interior features found only in '67. More discussion of that can be found in that forum, starting with some of it here:
https://www.ford-trucks.com/forums/4...ml#post3222835
Rickyrobert
May 21, 2017 05:05 PM
