Bronco II Ford Bronco II
2.9 replacement
Old Feb 20, 2024 | 07:07 AM
Barry Williams's Avatar
Barry Williams
2nd Gear
2.9 replacement
I have a 88 B2 Eddie Bauer automatic that I am considering swapping for a 302. Any suggestions on how to do it or what 302 t0 use? Are there any parts on my 2,9 that would be used on the 302 ? Can I use my 2.9 dash? Is there a step by step manual available on how do do it, After all is said and done is it worth it or just replace with another 2,9 ?
Old Feb 20, 2024 | 03:45 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I have not looked but I’m sure there are lots of swap threads. I would get a late ‘88 or newer 302 block so you can use a roller camshaft.
Like what? The Cologne (Germany) 2.9L and 302 have nothing in common. They are completely different.
I don’t understand the question about using the 2.9 dash. What does the dashboard have to do with replacing the engine?
I had the engine in my ‘89 rebuilt a couple years ago. That would be the easier way to go. It has enough power for daily driving. Are you using the truck for something other than as a commuter?
Old Rust Bucket
Feb 12, 2007 08:08 PM
ShawnZ
Bronco II
Sep 22, 2006 03:49 AM
siphor84
Oct 3, 2003 01:34 PM
fordtrck302
Jan 29, 2003 04:35 PM
794wd
Jun 13, 2002 11:08 PM
