1 3/4" Headers - Do they exist?!
Old Nov 24, 2003 | 04:46 PM
90f150moneypit's Avatar
90f150moneypit
I thought I had it all planned out!
I will be needing 1 3/4" primary tube headers for the pit when I get done with the 418W build.
I found the perfect set on the Hedman header site, Extreme Duty. They were listed as 1 3/4"X3" for 2WD with 351W.
Then I go to the Summit site to see if they carry them, they did.
Problem?
On the Summit site they are listed as 1 1/2"......not 1 3/4".
I went back to the Hedman site and noticed they have a set listed for 4WD with 351W with the same part number (89278). Only they are listed as 1 1/2"!!
I sent an email to Hedman to see if there was a typo and just received their response. The header (89278) is indeed 1 1/2"X3".
I am pretty sure 1 1/2" or even 1 5/8" headers will choke a 418cid too much. I may have to shell out the big bucks for custom headers, but no one within 250 miles can handle that.....
Soooo
Does anyone know who makes a 1 3/4" LT header for a mid 80's to early 90's truck with a 351W?
Old Nov 24, 2003 | 10:36 PM
jesse460's Avatar
jesse460
pickrel has them they cost $399 http://www.pickrelperformance.com/ca...6544e319d0c695
Old Nov 25, 2003 | 12:58 PM
90f150moneypit
AHHH!!
Thank you!!
Old Nov 25, 2003 | 07:48 PM
jesse460's Avatar
jesse460
are you running the 4.1 scat crank? do you know if scat makes a 4.17 crank? i am building a 427 windsor i was going to use a cast crank but it wont hold up if i decide to use nitrous
Old Nov 25, 2003 | 09:06 PM
90f150moneypit
I'll be using a Scat forged crank. Scat doesn't make a 4.17" stroke crank, I wish they did.
I guess Speedomotive sells a 427 rotating assembly, but they are not the best quality. Scat isn't the best either but rank up there.
Brian460
1978 - 1996 Big Bronco
Apr 18, 2011 10:54 PM
CRUNKED77FORD
Nov 30, 2010 11:44 AM
Sawsall
Feb 29, 2008 06:03 PM
JCool
May 23, 2003 09:06 PM
