99 2wd question
Old Feb 16, 2024 | 10:36 AM
MD_7.three's Avatar
MD_7.three
99 2wd question
I know this isn't specific to the 7.3, and but I thought it might get more traction here than the 99-2017 SD forum...
I tried searching on here but couldn't find much so I figured I would ask.
I have a L99 7.3L F250 2wd (build date 1/99)
I need to replace the front rotors and pads, and I think the wheel bearings are integrated into the rotors (these pre 3/99 builds are the ones with the wheel studs pressed into the rotors). Just looking for some help making sure that I order all the correct parts and I'm not over-looking anything that should/could be easily replaced "while I'm in there"
1xPowerstop Front Rotor's / Pads
2xTimken Set 47 Inner bearing/race set
2xTimken 15101 outer bearing
2xTimken 710413 spindle seal
2xTimken 4160 wheel seal
2xDorman Dust caps
Appreciate any help you can provide!
Old Feb 16, 2024 | 03:07 PM
udsuth78's Avatar
udsuth78
Looks good except you'll probably want those outer bearing races too. Looks like Timken #15245.
Old Feb 16, 2024 | 03:42 PM
MD_7.three's Avatar
MD_7.three
good catch I missed that when I didn’t see the set like they had for the inners.
Old Feb 16, 2024 | 06:52 PM
z31freakify's Avatar
z31freakify
Usually new hub-rotors come with the races already pressed in, a quick Google image search shows powerstop already has them pressed in. Also make sure you don't have 4 wheel abs, as there two type of rotors, one with a ln abs tone ring and one with out
Old Feb 16, 2024 | 06:57 PM
MD_7.three's Avatar
MD_7.three
Thanks, pretty sure I have 2 wheel abs, didn’t see a wire coming from the front hub. How else would I verify?
Old Feb 16, 2024 | 07:45 PM
z31freakify
If no wire for abs goes to the front rotor then you dont have AED ABS.
Even if it was an AWD ABS rotor it still would fit, the concern was if your current truck has awd abs.
MD_7.three
Feb 16, 2024 10:34 AM
ShelbyHauler
Apr 22, 2021 11:24 PM
o4SCrew
2004 - 2008 F150
32
May 27, 2007 11:15 AM
71-4R3SONS
Mar 11, 2006 01:27 PM
MarkA100
1997 - 2003 F150
Aug 22, 2004 09:24 PM
