Ford Excursion V10 stalling in reverse only when backing downhill.
Old Feb 13, 2024 | 11:05 PM
Excursion10's Avatar
Excursion10
8th Gear
I have a 2000 ford excursion V10, and recently it’s been stalling in reverse. It started when I was towing a camper down a very steep mountain road, and was engine braking in first gear for about 10 minutes. I have a digital temp gauge and have never gone over 220 degrees. It doesn’t happen all the time, only when I am backing down a hill (front tires above rear tires) with no load on the engine. If I am aimed uphill when I back up, I can sit there with my foot on the brake forever and it won’t stall. If I am on the same road but turned around so I am aimed downhill when I back up, it will stall within 2 seconds. Any ideas for this? The trans fluid level looks good but the dipstick is hard to read. I have about 136k miles. Had a trans fluid drain and fill and filter replaced at about 125k miles.
Old Feb 14, 2024 | 12:36 PM
WE3ZS's Avatar
WE3ZS
Is this condition fuel level dependent? Same thing happens no matter the fuel level?
Old Feb 17, 2024 | 12:08 PM
Excursion10
8th Gear
yes, I usually keep it over a half tank and haven’t noticed any changes. This does happen less when it’s fully warmed up, but has still occasionally happened.
Old Feb 18, 2024 | 10:21 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
@Excursion10
Do you have the original Ford stamped steel transmission pan?
If not, which aftermarket transmission pan do you have, if you know?
When you checked your transmission fluid level, was your engine running?
What EXACT transmission fluid did you use when you drained and refilled it at 125K miles?
(Be very specific with your identification of transmission fluid, including the name brand, and a link to the product online so that the specifications can be seen)
When you pulled your old transmission pan filter, did you also retrieve the old O ring for that old filter from the orifice in which the top of the filter is inserted, prior to installing the new filter?
Old Feb 18, 2024 | 05:13 PM
Excursion10
8th Gear
Originally Posted by Y2KW57
@Excursion10
Hello, thanks for the detailed reply. Yes I have the original trans pan. I checked the fluid level running in neutral with parking brake on, trans was warmed up maybe 150 degrees. For trans fluid I used 17 quarts motorcraft mercon V (part number XT5QMC as I saw recommended after tons of research. And yes, I made sure to remove the old o-ring on the filter that’s on the top of it before using the new one. I used a Wix filter as I’ve always heard good things about them. Since the fluid change I was towing ann RV- around 8000 pounds near constantly, all over the Rocky Mountains and in very hot places like Utah and Arizona. Everything else has been perfect except for this stalling in reverse.
m-chan68
Aug 3, 2021 11:28 AM
KnfMkAR
Modular V10 (6.8l)
Dec 22, 2020 05:12 PM
KnfMkAR
Dec 21, 2020 01:06 PM
jspringator
Jan 13, 2016 07:27 PM
