Heater fan
Old Feb 13, 2024 | 09:57 PM
Samsonsford's Avatar
Samsonsford
Heater fan
I went to turn on defroster and nothing. Tracked down the fuse location, pulled it (30 amp) It appeared to be blown,very dusty, former quarry truck, and replaced it. When I turned on the fan again it sparked and blew instantly. Any suggestions on fixing it would be great. Thanks
Old Feb 14, 2024 | 07:23 AM
97-psd's Avatar
97-psd
I would start with the resistor pack. It may be shorted.
Old Feb 14, 2024 | 07:25 AM
97-psd's Avatar
97-psd
Something like this:
https://www.rockauto.com/en/catalog/...+resistor,6557
I am trying to remember if it is under the dash or on the blower box under the hood
Old Feb 14, 2024 | 08:43 AM
knottyrope's Avatar
knottyrope
do the blower and resistor as a set
Resistor is near the passenger Head under the hood
Easier to remove blower fan first, clean out all the gunk insides ( I HOESD IT DOWN) and then do resistor
Old Feb 14, 2024 | 09:15 AM
Samsonsford
Thanks, very helpful as usual. I would be lost without you folks!
Old Feb 14, 2024 | 01:13 PM
farmert's Avatar
farmert
Usually if the resister is bad, you will have only 1 speed with the blower. I'm betting the motor is bad.
Old Feb 14, 2024 | 05:48 PM
Samsonsford
Thanks. Would a bad motor blow the fuse?
Old Feb 15, 2024 | 06:36 AM
tjc transport's Avatar
tjc transport
i ain't rite
yes it will.
and as already said, just get a resister while you are at it.
nothing worse than getting it all together to find you only have one blower speed and have to take the truck back apart.
Old Feb 15, 2024 | 08:12 AM
knottyrope's Avatar
knottyrope
I ended up needing a resistor pigtail, resistor and blower
I had a lot more air flow after and my ducts were clogged with leaves and a nest.
The evap and heater core were plugged up with dusty gunk too
After many years, you just need to go through it all to be sure
I dont like doing things twice unless its fun
Old Feb 15, 2024 | 09:15 AM
Hit Man X's Avatar
Hit Man X
Need to see if that is the correct fuse for that slot too, I do not have my EVTM handy or I would check for you. Luckily this is an easy fix.
While in there, buy some foaming evap cleaner and spray it up in that evap case. They usually come with a hose to poke it into odd spots. They are always full of ****...this will be very true if old quarry truck.
Old Feb 16, 2024 | 07:05 AM
Samsonsford
Thanks . I am going into it today if the rain lets up a bit.
Old Feb 16, 2024 | 08:52 PM
Samsonsford
The motor is full of dust and acorns. Are they supposed to be there? What brand of acorns do you guys use?
Old Feb 17, 2024 | 06:07 AM
tjc transport
i ain't rite
the best acorns to use are from old growth Spanish oaks.
there should not be any dust at all. that means there is no water to keep the dust as a moist soil so the acorns will grow into more strong oak trees.
Old Feb 17, 2024 | 09:07 AM
Samsonsford
Thanks. I guess I should put in a drip system now.
jinxs
Jan 23, 2012 08:34 PM
secakc
Jan 29, 2011 04:53 PM
secakc
Electrical Systems/Wiring
Jan 26, 2011 09:33 AM
cookkd
Aerostar
Jun 26, 2004 07:00 AM
slmd350
Oct 5, 2003 07:51 PM
