ignition swap
Old Nov 24, 2003 | 01:57 PM
f100guy's Avatar
f100guy
ignition swap
what is involved in switching from tfi to a duraspark ignition on a 91 tbird with a built 302 out of a truck with a carb. how hard would it be. and with the fuel injection harnesses unhooked and just the altenator hooked up to the harness would it still charge.
Old Nov 24, 2003 | 07:34 PM
Franklin2's Avatar
Franklin2
This should get you going on the duraspark conversion.
Make sure the alternator is wired like this and it will charge. Ignore the choke wire if you don't want to hook it up.
Old Nov 24, 2003 | 08:17 PM
f100guy's Avatar
f100guy
thanks
