Help
Old Feb 11, 2024 | 10:56 PM
Jdundo's Avatar
Jdundo
1st Gear
Help
help. I've had a misfire since i got the truck. Replaced vss, numerous parts. Today I started it and it ran rough. Spitting smoke of different colors. I can't tell if it's blue or white but the occasional black puff comes out. This time when I started it again today about 5 minutes ago, the fuel pump is running constantly with key on. Running really rough. Shut off completely with clicking noises coming from under the hood.
Old Feb 11, 2024 | 11:15 PM
Prototypemech's Avatar
Prototypemech
Constantly running fuel pump is a sign of a failed ECU. Try to pull engine codes and see if thats possible. If you can't pull the codes, that's definitely a sign of a failed ecu. Start looking for a replacement ECU.
Yyou can remove the computer and open up the lid to look for leaking capacitors. That's the most common failure. Luckily, it's repairable most of the time.
Billybob1995
41
Feb 18, 2023 06:35 AM
BigRed7.3l
Jul 14, 2014 10:33 PM
9d4
Oct 16, 2012 09:36 AM
ldfry001
Jul 10, 2009 04:24 PM
wmiller
Dec 9, 2008 11:16 PM
