Water Pump Replacement
Old Nov 24, 2003 | 12:57 PM
HLUNA's Avatar
HLUNA
Need some help on what is special on replacing water pump on my Excursion...
Also, since there has been a leak on water pump, the heater and AC only blows from top vents not front? Any ideas?
Old Nov 24, 2003 | 12:59 PM
HLUNA's Avatar
HLUNA
BTW, it is a Diesel...
Old Nov 24, 2003 | 11:09 PM
Rodneys's Avatar
Rodneys
HLuna
I have a 2000 that had a water pump go out. It is covered under the 100,000 mile factory warranty and anything from the affects are covered.
Good luck
Rodney
Old Nov 25, 2003 | 09:40 AM
HLUNA's Avatar
HLUNA
WHAT?
I did not purchase the 100K extended warranty. Yesterday I replaced the pump, but it took me 4HRS because I did not have all the right tools. The last thing I had to do was put the belt on correctly, but I must have missed a spline and it ripped the serpentine. I am going to go buy a new one today. Total parts and tools from Napa including new thermostat, $320. Dealer wanted nearly a $1000. ALSO, what would cause the air conditioning and heater to only blow up top and not through the front vents? Thanks for any help!
Old Nov 25, 2003 | 02:43 PM
Rodneys's Avatar
Rodneys
I would still be talking to Ford. The 100,00 mile warranty is on all diesel engines. There was a $100.00 deducable when I had it done. I have the reciepts if it helps.
Rodney
Old Nov 25, 2003 | 04:39 PM
2000XPSD's Avatar
2000XPSD
nothing special about changing it out except that you need a Fan Pulley Holding Wrench 303-478 and Fan Clutch Nut Wrench 303-214
Old Nov 25, 2003 | 07:05 PM
HLUNA's Avatar
HLUNA
Well, it looks like I successfully completed the install of the water pump, and have a call to my local dealer to check on my warranty...AFTER THE FACT...but I still have the air ONLY blowing from the top vents and not the front? Any help....
BTW, my Excursion has run very well since I have bought it...and I love it! I tow a 9500LB Boat with her, and she doesn't even hesitate....
PS...that wrench was a life saver....I found it at NAPA for 20 bucks..
