Question about a part name
Old Nov 24, 2003 | 12:05 PM
150ex's Avatar
150ex
The rubber between the bottom of the door window and the outside of the door (in other words, the rubber that would wipe your window clean if you rolled down the window); mine needs to be replaced. Can anyone tell me what that is called so that I know what to ask for when looking for it?
Thanks.
Old Nov 24, 2003 | 01:02 PM
smaynor's Avatar
smaynor
They are called anti-rattlers. They are not difficult to install, but you will destroy the old ones when you take them out. So, don't take yours out until you get your new ones. They are available from many different sources.
Good luck,
Old Nov 24, 2003 | 02:59 PM
Torque1st's Avatar
Torque1st
Posting Legend
door belt weatherstrip, inner and outer.
Old Nov 24, 2003 | 03:01 PM
150ex's Avatar
150ex
Much Obliged
Thanks for the information.
Old Nov 25, 2003 | 06:01 PM
79blueoval's Avatar
79blueoval
Somtimes they are called scrapers.
Old Nov 26, 2003 | 05:08 PM
highboy 74's Avatar
highboy 74
Just one note about installation. When you put the new ones on sometimes they do not install tightly against the door and it may leave a sliver of a gap that water can run past. So what I did was use black silicone between the door and the rubber. It worked very well. And it looks professional as well. There is also a gap between wing window post and the door. This gap should be filled with silicone as well.
Old Nov 26, 2003 | 10:47 PM
bigsnag's Avatar
bigsnag
I bought some from JC Whitney and they were pretty cheap but seem to be decent quality. I have no doubt that the ones from Motor Haven are great too.
