Aries Electric Steps- Highly Recommend
Old Feb 4, 2024 | 10:02 PM
Badaxe's Avatar
Badaxe
Trailering
So the first time I brought home the lifted Excursion my wife acted like she was climbing a mountain to get in. So to nip any anti lift sentiment in bud I had to act fast.
After lots of measuring at least twice and verifying install process videos I pulled the trigger, and these were exactly the perfect upgrade to my running boards. Not only did it add a step, but it made easier access paired with my 6" lift. The stock drop running board sat at 19” high. The new Aries steps it at 15” for the drop step and 24” to the top step. Bolting the steps in was a breeze using existing mounts, and the kit comes with all the needed hardware if it’s a new installation.
There were a couple MINOR wiring harness challenges to get past, since the pre-made harness was designed for the F-series vs the Excursion. The control box should land under the rear passenger seat, however with the excursion mount it fits nicely behind the rear passenger side paneling next to the third row with wire harness running in the base corner of the third row step up. As the harness works its way upstream because of that “one foot shift”. The factory included extensions were not needed, but it did take a little improv for switch mounts and power wiring. My switch sits just left of the parking brake release, out of the way but easily accessible.
Instead of using, what I think is a cheap cop-out (the included light) I used a ONERAY 2PCS 60inch IP68 LED Running Board Light spliced into the factory plug. The key I discovered after trouble shooting was to remove the rear cap, slide the light strip in from behind the motor, and stick it right down the center of the upper side (so the steps don’t bind as it closes).
Original running boards
Aries Steps up
Aries Steps down
LED Strip
LED Strip (no flash)
Old Feb 5, 2024 | 09:43 AM
John in OkieLand's Avatar
John in OkieLand
I bought the ARM Research electric steps, at $1500 plus installed, they are not cheap.
But the step is almost 8 inches wide, and has been a blessing for my 81 years of wear and tear.
Old Feb 5, 2024 | 01:20 PM
Badaxe's Avatar
Badaxe
Trailering
I like AMP Research too, but between my wife's stature and the size of my Excursion a lower and additional step was the way to go. The upper step also assists as a platform to reach the roof.
Old Feb 5, 2024 | 08:18 PM
Antonm23's Avatar
Antonm23
Those are freaking sweet, got a link to where you got them?
Old Feb 5, 2024 | 09:15 PM
Badaxe's Avatar
Badaxe
Trailering
As you may know we have to shop F-250 crew cab parts options. They don't list them for our Excursions, but they fit our wheelbase perfectly.
https://realtruck.com/p/aries-action...2a0aa0e59c5356
Amazon Amazon
excursion_7.3
Nov 23, 2023 06:32 AM
Squirrel13
Jul 18, 2021 07:11 AM
JWA
Jul 18, 2020 08:43 AM
Board4RD
15
Apr 13, 2020 02:32 PM
eurojet
2015 - 2020 F150
20
Jun 9, 2018 04:51 AM
