1978 - 1996 Big Bronco
1990 bronco problems
Old Nov 24, 2003 | 09:19 AM
rusty1990351's Avatar
rusty1990351
1990 bronco
Hi,
I have a 1990 351w fullsize bronco and It keeps make a vibration Usualy when I accelerate and I have changed all the u-joints and it still does this. I pretty sure it the rear driveshaft because I drove the truck around for five days and didnt do it with the the rear drive shaft out and it started as soon as I put it back in from changing the u-joint. so if anyone knows what it could be or I to fix it I sure would appreciate it.
Old Nov 24, 2003 | 10:20 AM
rusty1990351
Hi,
I have a 1990 351w Bronco. It keeps making this bad sound, well its actually more of a vibration when I start to acclerate. At first I thought that it was the rear u-joints going out so took the driveshaft out and had all of the ujoints changed, and while the rear driveshaft was out I had to have a way to get back and forth to work so I put it in 4x4 and sure enough whithin the four day period the rear driveshaft was out it didnt make the shuddering or the vibration when I was driving and that made me feel even more like the rear u-joint was where the problem was, well after I have the driveshaft put back in with the new u-joints It starts to vibrate again when I accelerate just like it did before.I'm really not this experinced with this part of a truck so If anyone knows whats causing this or how it can be fixed I sure would appreciate your help.and once again it a 1990 fullsize Bronco with a 351w and it has automatic locking hubs,if you need more information just ask.
thanks,
rusty
Old Nov 24, 2003 | 12:01 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello-
Welcome to Ford Truck Enthusiasts! The Internet's leading Ford TRUCK and SUV Resource!
This thread has been moved from Garage and Workshop Tips forum where we share ideas about how to organize tools, heat the shop, or free that rusty bolt.
Unfortunately no truck tech questions are allowed there. Please scan down the list of available forums and place your topic in the most specific forum you can find, -fairly simple to do and just takes a moment.
Please take the time to read the headings and notices in each forum. The FTE board is HUGE! We want users to be able to find answers to their questions so it is organized into many areas and search tools are provided.
If you have any questions please feel free to contact a moderator.
Please turn on your email function. Users do not have access to your actual email address.
Thanks for using FTE!
-note- 2 posts combined and moved to proper forum from Garage and Workshop forum.
Old Nov 26, 2003 | 09:41 AM
kilted_drummer's Avatar
kilted_drummer
I have a similar vibration. It is during acceleration also. At first it appears to be the ujoints be cause it backs of when you let off the gas. I have checked them out and they seem fine. I am really starting to think it is engine bearings. I have 190k on it. What is the mileage on both your vehicles??
Old Nov 26, 2003 | 10:02 AM
Kemicalburns's Avatar
Kemicalburns
you may want to check your pinion nut. they can losen up and cause such a vibration. are there any dents or dings in the driveshaft. if so it may need to be balanced or possibly get a new one.
good luck
Old Nov 26, 2003 | 11:00 AM
kilted_drummer
what is the pinion nut?
Old Nov 26, 2003 | 11:03 AM
Kemicalburns
where your rear driveshaft connects to the rear axle. If you disconnect the ujoint from the rear diff there should be a Nut there that holds the pinion. who put the ujoints in? did you have a driveline shop do the work if so might take it back and have them check the balance .
Old Nov 26, 2003 | 11:12 AM
kilted_drummer
this post, I think, is following the lines of the *u-joint replacement* post...sounds like the same thing to me
