chip or shift kit
Old Nov 24, 2003 | 08:13 AM
panteramatt's Avatar
panteramatt
chip or shift kit
I have a 93 f-150 4x4 with a 302 and a full exhaust and the tranny shifts WAY too soft and takes forever to shift.What would be better a shift kit or chip to add firmness.Whats healthier for the tranny and I want to still use 87 octane but I would have to pay for installation of the shift kit but not the chip.
Old Nov 28, 2003 | 05:23 PM
Fully_Loaded's Avatar
Fully_Loaded
I would go with the shift kit. A little more expensive but worth it.
Old Nov 28, 2003 | 05:32 PM
91f2504x4's Avatar
91f2504x4
yeah I have read that most chips require you to run higher octane fuel and I don't think they could improve actual shifting firmness much , just shift points , I would definatly go with the shift kit if you want real results
Old Nov 28, 2003 | 07:17 PM
95 F150's Avatar
95 F150
Is it safe to put a shift kit on a high mileage trans.?. I've heard it was a bad idea.
Old Nov 29, 2003 | 01:08 AM
91f2504x4's Avatar
91f2504x4
I would think so , with a shift kit it engages much firmer therefore slipping less which I think would be better on everything in the transmission , probably not as good for U joints and rear ends though , o well , firmer shift means less slipping and less slipping is less heat so I would think it almost has to be better.
Old Nov 29, 2003 | 04:17 AM
Supercab's Avatar
Supercab
Cool
What is the best shift kit for these E4ods??
