nope…. And I’m thinking the mechanic over tightened them…. When I turn the clamp it just never gets tight and it’s not stripped which leads me to believe it is crushing it… also low boost
definitely a lot easier than installing new plenums
Would be worth checking current plenums for boost leaks as if they are leaky they'll have to be redone anyway (oil exposure can, over time, make the silicone a bit loose on them in my experience).
Curious how that worked out. How long on the fix and any oddball issues?
it was straight forward, i watched an old video that said to cut the bolt out up near the hpop, DO NOT CUT THE BOLT, the new plenums have a slit cut because you cant pull the bolt out completely
Out of curiosity why a lack of faith in the o-rings? RR says they'll take 150 PSI of boost.
the O-rings thread into a small passage on the intake plenum, without the assistance of some type of adhesive to hold them in place i wasn’t sure they would stay put during the installation
