Front end rumble
Old Nov 24, 2003 | 06:50 AM
FINFEVER's Avatar
FINFEVER
Front end rumble
HELP!!!!!!!!
I have a mostly low speed noise(imagine a tire with a flat spot) that speeds up with truck speed mostly from take off to about 35-40 mph.The sound is more like a growl, not constant but one noise with every revolution of the tire. Jacking the front end up and spinning the wheels shows nothing except the slight rotor drag. Recently I`ve been noticing a resulting vibration at higher speeds. Any ideas friends?
Old Nov 24, 2003 | 07:13 AM
jswanberg10's Avatar
jswanberg10
Run your palm, flat along the inside and outside of the tire and see if you can feel "cupping." It'll feel like small waves in your tires. What you're describing sounds just like cupping and it's due to a poor suspension or your frong end is out of alignment. Also, there's nothing you can do about correcting the tire condition besides replacing the tire.....
sorry.
Old Nov 24, 2003 | 10:16 AM
buzzard's Avatar
buzzard
Is your truck 4wd?
While your prob is most likely tire related, your front differential might need servicing if you're a 4x4.
Old Nov 25, 2003 | 01:22 PM
sunnydude's Avatar
sunnydude
I have the same problem with my 03. First we noticed the grinding noise when turning. Now we are getting a nice shuddering noise until we reach about 40mph. We only have 8k on the truck as of today. Dealer said they would look at it when i take it in to have the passenger seat subframe replaced to stop the creaking sound.
Old Dec 13, 2003 | 08:26 PM
Shaggy29's Avatar
Shaggy29
I am getting the same kind of shuddering/grinding nose. Did the dealer figure out what the problem was?
racngrn
Oct 1, 2015 07:03 PM
cuda66
Mar 6, 2014 05:56 AM
Taffy.C
Oct 29, 2013 11:43 PM
brianjordanf250
Apr 28, 2013 10:23 AM
vess
Jan 3, 2001 11:44 AM
