49 fuel pump
Old Jan 23, 2024 | 09:11 PM
Vinford's Avatar
Vinford
49 fuel pump
49 fuel pump ? Can anyone tell me what flathead 8 used for a fuel pump?
Old Jan 23, 2024 | 09:21 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Current inventories would be one of the following:
Airtex 578
Airtex 9785
Carter M826
Napa FUP B0012P
Old Jan 23, 2024 | 09:26 PM
Vinford's Avatar
Vinford
So not electric?
Old Jan 23, 2024 | 09:35 PM
bmoran4's Avatar
bmoran4
No, Ford didn't use electric.
If considering use of an electric fuel pump, take the following points:
  • The electric pump must be compatible with a 6V positive ground power source
  • 3-4 psi fuel pressure. Any higher will overcome the carburetor float.
  • Safety shutoff - you will need a safety shut off. This usually involves the addition of an oil pressure switch and crank override electrical circuitry
  • Do not use an electric pump to move fuel through the original mechanical pump. You risk filling the crankcase with fuel.
My fleet are all running original style mechanical pumps and I have no need to think about electric conversion.
Old Jan 24, 2024 | 10:20 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Is this for the 3-ton F-7/8 you asked about in another thread? Is the engine a 239 c.i. flathead or a 337 c.i. ? Big difference. I would think the F-7/8 trucks would have the 337.
Old Jan 24, 2024 | 11:36 AM
bmoran4's Avatar
bmoran4
If it is a 337, then the Ford Fuel pump (8EQ-9350) is also a vacuum pump. Most current inventory would be of the 9206 variety from Airtex and others.
